Communication-Signal transmission -1.5kM - Better option
Selk
Aug 2019
Dammam
I am looking for a method which transmit OPEN/CLOSE signal from "A" Pump Station to "B" Pump Station.
(a) There is no wire connection between two Pump Stations, 1.5km apart.
(b) Ordinary wireless device is prohibited to use.
(c) Mobile telephones work at both Pump Stations.
(d) Internet service is not available at both Pump Stations, but probably set up newly if required.
Thank you!
Is there a PLC or RTU capable of communications at both ends? If so, using a radio modem to set up communications is one option. For 1.5km you might be able to use the Schneider Trio JR900 series licence free model, depends on local obstructions and radio spectrum licensing in your country.
If thats a bit over kill, take a look at Elpro wireless I/O
Hello folks, Hope everyone is doing well. I am a beginner at working in analog signals with PLC Analog module: 1769-IF4 ( 4 analog inputs ) PLC...
1,363
Hi all. I have a Modbus ProSoft module in my setup with a capability of 30 clients (0-29), which I'm trying to monitor the Ethernet Connection...
34
Hi folks, I have a Controllogix in communication with a zigbee coordinator using Logix AIO for modbus tcp. This zigbee coordinator have 3 slaves...
167
Hello, i am using profibus as communication between plc and fanuc arm. I can easily send inputs from plc to arm, but i can't monitor any outputs...
46
I have Woodward Controller EASYGEN-3500XT and Phoenixcontact make IO CAN-CUPLER part no: 2702230, Analog Input card: 2861412, Analog Output Card ...
47
