Communication using ASCII
I tried Rons' idea and connected it to hyperterminal and nothing is displaying on the screen. I had to shut down Linx in order to use com1. I will check my email now.
then maybe you don't have HyperTerminal set up correctly ... the code I posted works fine for me – see the HyperTerminal display at the right side of the picture ... (note that my Channel 0 was set for SYSTEM mode during the test) ...
why? ... are you using the COM1 port on your computer for RSLogix500? ...
when we talked earlier I thought that you said that you have a SEPARATE computer that you can run HyperTerminal on for testing purposes ...
Ok, it is working like a champ now. I kind of figured it had to do with the display itself, and it was. Format MUST look like this: NxxIxxd6,d5,d4,d3,d2,d1, <cr>, or it will not work. Thanks guy's, I could never have done this without your support.
Nxx= display address
Ixx= user input function (if not used you must still enter a "00".
d-6 thru d-1= ASCII data
<cr>
Hope this helps someone else in the future.
I was wrong about shutting down Linx. It is using Com5, the hyperterminal is using Com1.
When I load the program attached it times-down and every 30 seconds it displays another "30". So my screen looks like this:
30
30
30
30
30.....
30
30
30
30
30.....
attach your program and we'll check it - or just double-check the addresses of the TIMERS yourself ... sounds like you've got a typographical error ... the number should increment by ONE each second ...
For my application, I want to send and recieve custom ASCII characters through serial port. Can Omron CS1H PLC can do that ? ( Like user protocol...
7,126
I'm trying to write a data in Arduino using MODWR function block .I used the code I got from online for both PLC and Arduino. I made the wiring...
157
Hello everyone, I am trying to change the IP address of the Omron PLC (NJ30-1200) and HMI (NB7W-TW01B) to fetch the network on our network...
306
I am trying to establish communication between Siemens PLC 1500 and Matlab. I followed a tutorial on youtube at this link: But when I got to the...
368
I have wasted a week trying to figure out how to connect an SLC5/03 with my laptop. I do not have and can not Buy the 1747 UIC and PC3 cables. I...
2,578
