communication wincc .Q series and s7 300
ajay34
May 2010
klang
249
dear sir ..
i have 2 diffrent plc to run system ..which 1 was seimens s7 300 and mitshubishi Q series.
using only wincc flexiable to run part of system. meaning s7 300 run by wincc flexiable,,
i wantted to do new but due to limited budget of company..i had this suggestion..
where i 4 number of pc install with wincc flexiable sp3 and using pc server as well..
coonect all pc via profibus hub and connection to s7-300 and mitshubishi..
can this be done..i had try to figure it but lack of idea..attahc the drawing of what i mean to do
I have created a project in TIA Portal v16 Upd6 with S7-1200 (6ES7214-1AG40-0XB0) and WinCC Unified (PC station). The communication between the...
159
In our production plant we have multiple different networks (subnets). IT dept have setup routing between them so different subnets can...
112
Is it possible to connect a PC with running WinCC Advanced or Unified to a siemens PLC such as S7-1200 across different subnets? The computers can...
95
Hello, I want to establish LTE communications (2 S7-1200) with common Workstation. All i have is 1200CPU with 6GK7243-7KX30-0XE0...
327
Hello, iam a newbie in wincc operations. But I am a hard/soft engineer. In my father'r company, they have used a wincc based project to...
371
