Communication with 2 plc's over profibus
wdulli
Feb 2009
NL
Hi all,
i'am making a project ( school ) with 3 plc's. I;am using plc's from siemens ( PLC 300 CPU ). There all connected with eachtother with profibus.
I'am stuck with this... How can i send data over profibus. For example i want to 'set' the motor from a conveyer on a PLC2 and when he is done ( sensor x is reached ) it must set a MemBit back to the PLC1. I have searched but with for example SFC65 and SFC66 is only with MPI ( correct me if i'am wrong )
How can i make this work???
Thanks in advance
Hello
If you only need the profibus connection to connect the 300 CPU,s so not for remote I/O for example ET200 S or ET200 M I/O then it would be possible to make one PLC profibus master and the other two plc,s a profibus slave.
In this way it would be possible to set up communication between the PLC,s over profibus.
This is the most low cost configuration,otherwise you have to make use of profibus cp cards or so called DP-DP couplers.
Regards
Henny
Dear Sir, I have a healthy profibus communication between SIEMENS PLC S7 400 and Allen Bradley drive PF700 using 20-comm-p profibus dp module...
2,826
Dear All, Here i have used siemens s7-400 PlC system. I want to communicate the schneider premium plc(TSX57203 processor) on profibus network...
3,814
Hi, I am trying to get communication between Siemens S7 400 CPU & Rotork actuator. I have already installed GSD file in HW config and downloaded...
4,023
One remote DP interface (IM 151-1) module of S7 PLC system going to stop suddenly. It is the farthest end.That module is supplied by a power...
2,884
I have a AB PLC5/60 that I need to communicate with a Rexroth hnc100 which uses Profibus, has anyone ever done this?
2,130
