Communications between A-B Flex I/O and a Scanner card
JoeBart
Guest
J
Hi All:
I am having trouble finding out if a A-B Flex I/O is communicating its analog signal through a twisted shielded pair wire to an A-B scanner card.
I checked the wire and found a resistance of 8 ohms between conductors which were tied together at one end about 650 feet away.
I checked for voltage at the connectors with the wires connected and had + 0.068 volts.
The problem is, I am getting my digital signal but not the analog signal. The analog module was replaced and its still not working. The only thing is that the scanner card has not been changed. Could that be it?
Anyway I need some advice on how to check this type of communications between PLC's.
You help will be most apreciated.
Joe
You stated
What digital signal do you mean?
What is the layout of flex i/o, is there more than just the analog module and everything else is working?
Do you have an actual signal value going into the analog card?
A little more info is needed to help you out
Drewcrew6
Hi Drewcrew:
I need to get the numbers off the units. I'll get back to you sometime today.
Joe
Hello, Current I am working on a school project involving PLCs and the PowerFlex 40 drive. The Drive is currently running though the Drive...
7,340
Multiple PLCs in our plant communicate using either MSG instructions or Produce/Consume. Is there an industry best practice for documenting this...
768
I am not great with Siemens and Profibus so looking for some advice. I have a project where I need to communicate approximately 20 status words...
1,670
Hey everyone. I am wokring on a supervisory application for our plant, and I am on the verge of cracking the final piece of the app that I have...
4,746
Hi Everyone, Helping out a friend out here and need some opinions. 2) AB PLC's separated by about 5 miles line of site. They are used for...
2,748
