Communications problem
CMalnar
Guest
C
I am having trouble understanding the concept of "data registers" and "control blocks". The application I am working on requires that I use these to send and recieve data from one PLC to the next. my project is as follows:
I am using two Aromat FPO PLCs on two diffenent systems, each is connected to an ethernet network via a cimerex 41 touch screen with built in ethernet and pass through functionality.
I can establish communications with each PLC via my pc though my router. The touch screens have a built in data transport protocal that allows them to act as clients or servers or both. The problem I am having is that in order to send and recieve the data, the touch screen requires that a data register is specified and also that a control block is specified.
I basically want each system to update the other on each other's condition. for example, cycle start, stop, e-stop, jams, and errors.
Any help would sure be appriciated.
Thanks,
Chuck
We have an OPC server getting data from a Compactlogix PLC. The PLC also communicates with a Panelview and a couple VFDs via Ethernet/IP...
1,167
Hi, I have an Electrocraft BSA30 drive that I'm trying to communicate with. I have my COM's set up correctly, but I get a port error. I'm using...
1,353
Hi, I just got a series 90 30 PLC and am trying to connect it to my laptop. I have the cheater cable connected to a USBtoRS232 into my laptop. I...
5,489
I am having some issues with my slc 500's keeping their ip addresses. I thought you guys might be able to confirm some of my thoughts. Anyways let...
1,978
I've got an encoder hooked up to a CUB5 and want to communicate with it from a G306A via RS232. I made two cables with pinouts per the G306A and...
1,937
