DamianInRochester
I have an installation with a Compact GuardLogix 5380 CPU [5069-L306ERS2] that is experiencing a strange issue I have never encountered before. It is controlling a network with about 8 other nodes, and is an application we have many of in the field almost identical, except we recently switched from Kinetix 300 drives to Kinetix5100.
The CPU will run for about 5 minutes and then will get an error that causes the OK led to go red. It will lose ethernet communication during this time and not communicate while in error. It will remain in error for several minutes, and then eventually auto-recover, go back into run mode, and begin operating again. It just continuously does this over and over again.
When in error, all other nodes on the network will ping except the CPU. When online with the CPU, no ethernet errors of any kind are logged.
No major or minor faults are logged. I added code to the controller fault handler with the hope of logging faults, but they all come up zero once communication is re-stablished.
I am debugging this remotely via a tunnel setup by a Tosibox. The network is otherwise isolated from external connection.
Anyone have any ideas on how I can determine what the actual fault is?
