Compact Logix 1769-L36ERM Ethernet
BlueAltezza
Nov 2012
Cleveland, OH
243
Quick question if anyone knows:
I see the 1769-L36ERM has two built in Ethernet ports. Can these be configured individually?
My customer requested a separate Ethernet module for plant communications (The machine and plant are both EthernetIP), but if the PLC can have that functionality built in then obviously I won't have to add another module.
The 'R' in the part number stands for 'Ring'. The two ports can participate in an Ethernet 'Device Level Ring' architecture, but the port has just one IP address.
If you need more than one IP interface, use the modular ControlLogix platform or install a router.
Hi
You could also use a l4x processor which will also allow you to add a second Ethernet card if you want to stay with compact logix
Donnchadh
Check out Allen-Bradley part# 9600-ENA. Its a NAT device that will let you translate a network address on one network to a device on another isolated network.
Also, not that if you use a L4x processor, you will be unable to use any firmware past version 20. I won't say they aren't supported, but the l4x series is no longer being developed.
Thanks for the replies everyone. I definitely have to look into the ENA module as that seems to be my only option (The L36 is set).
I was surprised to see that I couldn't simply add a communications expansion module to the system.
NAT translation or VLAN's is preferred over seperate NIC's I think. Somewhere out there is a great document by Cisco/RA about Ethernet/IP best practices. I like NAT translation, especially if I were a machine builder. Each machine could use the same addresses (192.168.1.x for example) and then those could be translated to suite a customers factory floor network scheme.
I dont know if you plan to use a switch in the machine or not, or if it will be a managed switch or not but aswell as the 9300-ENA module there is a NAT version of the 5700 switch that might be interesting if you plan on using a managed switch.
This is a massive advantage not just for the machine builder, imagine the client has a problem with two identical machines. You can tell him to swap pieces from one machine to the other without the need for him to change IP addresses etc. Also it eliminates the chance of an IP address conflict taking the whole network down as the worst that will happen is an IP conflict internal to the machine.
I have a Stratix-5700 sitting on my desk that was bought just for that reason. When i ordered a 9300-ENA, i set it up and had it working in about 5 minutes. Setup was pretty self explanatory. The Stratix switch on the other hand is a different story.
If you don't need the 5700 stratix switch for other reasons, I personally would not buy it just for the NAT capability.
Been seeing a high failure rate on these PLC's on 2 of our process. The control power is feed through a APC UPS to a 24VDC power supply to power...
4,050
Hello. I am trying to figure out how to setup a PID in Control Logix 1769 Controller in a way that it would control a drive speed by sending...
1,640
Hello guys, I need to add in a few discrete and analog cards for an existing 1769 Compact Logix system at a local Treatment Plant for an...
3,711
Hello Everyone, First of all, I would like to thank you for everyone who helped me in the previous post and this platform is really helpful for...
3,199
I am using ab 1769-l30er for redundancy logic, the secondary controller is not being recognized, the icon is replaced by a yellow question mark...
1,951
