Compact Logix Counter
Tutonka
Dec 2022
Pittsburgh, PA
I'm converting a Siemens S7-224 PLC application over to CompactLogix. In the Siemens program, 2 HSC inputs were used, so I am setting up four counters on my IB16F input module to mimic the Siemens function. It all seems pretty straight forward, but I do not see a controller tag to assign the preset value to the counter. What am I missing? The counters will be used to measure flow from a pulsed input.
I think you may only be able to reset to zero. The manual states that it only counts up too, so the preset shouldn't be a strict necessity, should it?
Hello Everyone, I have a issue with communication between two different PLCs. So here is the facts, The Master PLC is Guard Logix 5069 with IP...
124
gents, I am trying to configure communication with EMERSON PK300 controller through port A1 using generic ethernet communication module . I could...
134
I've blown the Output Transistor on the Output Card of a Compact Logix 1769-L24ER-QBFC1B It says J378. Does anyone know the replacement part...
208
267
I was wanting to see if anyone had any information on setting up a cub5 meter and getting the data to a Allen bradley PLC. I think i have the set...
143
