What transistor model for blown Compact Logix Output card?
vree.peter
Mar 2024
Toronto
I've blown the Output Transistor on the Output Card of a Compact Logix 1769-L24ER-QBFC1B
It says J378. Does anyone know the replacement part number.
Yes. I will be purchasing a new IO card, but would like to try to replace this transistor as well.
Google is your friend here. Do a search. The first hits lead me to this part. This looks like a Toshiba 2SJ378(TP,Q) TPS MOSFET P-CH 60V 5A TPS
My go to for looking up and sourcing chips are: Mouser & DigiKey.
Would recommend measuring the input and output voltage of the suspect mosfet in the on & off state compared to a working one before going through the trouble of replacing in case the problem is another component.
I have a CPU 214 S7/200 that has a blown transistor. It is marked as SJD1026. I can't find a datasheet for this component. Does anyone have one or...
547
Specing Point IO to drive 3w 24vdc pneumatic solenoids. Switching frequency is approx every 3.5 sec. Math puts that at .125 amps. Debating...
2,662
Hi, I have a cpm1a that has sinking transistor outputs. I have recently used this to power a relay coil. The relay coil is energised as soon as I...
1,979
Hello All, I need a bit of help utilizing a timer's DC transistor output to start/stop a motor with a VFD. The motor currently being utilized...
28
4,722
Hello all, Probably a newbie question, but how to program this (se picture) is it HZ saying something about total time, and duty saying somehing...
1,866
