Siemens S7/200 Transistor Replacement
PLC-Pro_AM
Nov 2023
Oregon
I have a CPU 214 S7/200 that has a blown transistor. It is marked as SJD1026. I can't find a datasheet for this component. Does anyone have one or know of a suitable replacement? Thanks!
google shows several random internet suppliers for components with similar names. Not sure how much you trust alibaba or whatever.
I've never seen "field repair guides" or anything similar for Siemens PLCs, for anything that would require soldering. They have accessories for extra terminal blocks and such, but not internal chips/components.
Unfortunately I don't trust the Alibaba type stuff. I'd rather just order a component from Digikey and have it here in a couple of days. I can drop a beefy Mosfet in there, but figured someone had done a quick field repair in the past. Otherwise it means ordering a used PLC and trying to transfer the program.
Hi all, Currently having trouble getting a speed reference to write over modbus to an Omron M1... I can successfully write a run command and...
257
commentaire communiqué siemens s7-1200 avec vfd delta ? (cablage et sur tia portal )
139
Hi, I have a 1214 on ip 192.168.0.100. This is connected to other modules through a switch on same network. I need to connect this to a company...
183
Hi Experts, I would like to make firmware upgrade from v3.0 to v4.5 (S7-1200 CPU 1215C). Can I do it from v3.0 to v4.5? Do I need to take some...
295
Hi Guys, I am trying to establish communication over profinet between Siemens S7-1200 PLC as IO device and codesys plc as IO controller. But I am...
43
2,883
