Compact Logix / VB6 / vHMI
cbeck77
Dec 2006
Mississippi
26
I am trying to connect to several tags with vHMI and VB6. The processor is a Compact Logix L35E. I have had no problems connecting to a single item but when trying to grab several integers I begin to have issues.
I will also want to add floats to what is pulled or pushed to the PLC. If anyone has some insight or sample code it would be most appreciated.
Hello Everyone, I have a issue with communication between two different PLCs. So here is the facts, The Master PLC is Guard Logix 5069 with IP...
135
gents, I am trying to configure communication with EMERSON PK300 controller through port A1 using generic ethernet communication module . I could...
139
I've blown the Output Transistor on the Output Card of a Compact Logix 1769-L24ER-QBFC1B It says J378. Does anyone know the replacement part...
210
291
I was wanting to see if anyone had any information on setting up a cub5 meter and getting the data to a Allen bradley PLC. I think i have the set...
145
