CompactLogic PLC Two Separate Banks
lsrautomation
Jun 2014
Gramercy
I have been programming a CompactLogix PLC that will operate with two banks (I've got 2 separate Power Supplies one 120/230VAC and the other 24VDC). I've attached a photo to show the orientation (excuse the cabinet wiring). The expansion cable used is 1769-CRL. A couple of questions:
1. Is it necessary to use the expansion cable even though I'm using two separate power supplies?
2. How will the slotting work? I have 9 total modules, so will the slotting simply be slots 1-9 in the programming?
Just a FYI, Rockwell has a free tool called Integrated Architecture Builder that is a big help when designing CompactLogix systems. Not only does it help with the numbering of your I/O, it simplifies the placement of power supplies, sizing of power supplies, types of endcaps needed, and any other gotchas that arise with designing CompactLogix "racks." It really helps to eliminate future surprises when designing larger systems.
Depending on which power supply you have, you may only need one bank for all your I/O.
Hello I need to message read the entire 16 channel raw analog inputs from a 1769-L33ER Compact Logic controller to another 1769-L33ER Compact...
258
Hello, I want to monitor Wonderware historian's heartbeat and trigger a fault if Historian is not communicating /offline in PLC. Currently my...
803
Hello Dear users, I am writing about a problem that has been bothering me for a few days, i.e. I am trying to establish remote access to the Allen...
105
I would like to connect the compactlogic PLC to our network through the A2 port to enable cloud datalogging, but concerned about potential...
1,517
Looking for AOI for Allen Bradley CompacLogix PAC for Statistical Process Control, SPC Functions like XBar, RBar,Average,etc: yakyak:
1,282
