CompactLogix 1769-L23E-QB1B will support the point IO 1734-IE8 module
ALT
Aug 2009
Hyderabad
45
Hai,I have simple configuration issue.Will compact logix 1769-L23E-QB1B support the Point IO 1734-IE8 module.I have treid configuring the module in the RSlogix-5000 but unable to create the IE8 Module with the 1734-AENT adapter.Please anybody suggest for this issue
I can't seem to make that configuration work at all, with the 1734-IE8C module. RSLogix won't accept it, however, I can generate one in RSNetWorx that can include it.
/Shrug.
It works in V18. What version are you using?
Also, make sure that under the general tab for the 1734-AENT module, in the module definition section that you set the "Chassis Size" to be greater than one. If it is one you will not be able to add any modules at all.
I didn't try 18, only 17. Probably going to stay with 16 too, until it's 100% unsupported.
Hmm... Also tried 17 and it also worked. I really think the Chassis size may be set to the default of 1. It need to be greater than one to define a module.
Darren
Odd... I just tried again, even with a large chassis size, and can't get that module to even show up. Possibly Logix doesn't recognize the EDS file?
I even tried dropping it into another project, with an L61 and ControlNet, no listing for the module in Logix, but it shows up fine in Networx Controlnet.
Good call Darren, I didn't even think to look there, but yep. It seems I'm missing a number of profiles that should have been installed with V17, but somehow never made it.
Original poster: Try that, download the add-on profile, install, and restart Logix.
I have Red Lion Panel view G306A which needs to be communicate with the CompactLogix 1769-L23E processor.Will it be compatible ? Please anybody...
6,980
Does anyone know what the data transfer rate for this series of CompactLogix PLC's? 1769-L24ER-QB1B to be exact. Cheers.
100
Hello all, and thank you in advance for any assistance you may be able to provide! This is my first post, so if I need to reformat or change...
490
We are trying to poll data coming from a PLC for remote monitoring we have the IP address of the PLC and the default port number and the path is...
25
590
Hey guys, On my system, i got prop valve controling cylinder on the left and right to adjust the center of a lumber before it get in a woodmill...
936
