CompactLogix 1769-L35E Processor unit.
Adam303
Aug 2009
Chicago
587
I HAVE A Compact logix processor that went dead on me for no particular reason on one of our equipment. I took all the I/O out and just used the power supply with the processor. When I turn on the power supply all the leds flash red once on the cpu and the power supply dies. Could the processor draw so much curren that it would kill the powersupply?I tested power supply and seem to be working properly. Could it be the processor itself that is bad?
My best guess is that there is damage to the power circuits inside the CPU, which is drawing enough current to make the power supply go into a protective shutdown.
My standard procedure with damaged controllers is to invert them over a clean piece of copy paper and bang them on the bench a few times. More than half the time I find metal debris from careless installation.
SPM would be associated with the speed of the vibration and that old annoying ring in the in my ears.
I sometimes miss that pounding of stamping presses.
I can actually say that I had a successful repair of a PV300 using this method.
When I got to site, the PV300 was dead, but I found that a new E/Stop had been installed above it that very day. The electrician did say that he covered up the PV300 with a rag before drilling...
I removed the PV300 from the panel, tapped it onto a sheet of paper to collect the swarf, and hey presto, the PV300 came to life.
Sometimes you get lucky
Hi, I am new to PLC and seeking advice here. We have a compactlogix 1769-L35E. The L35E has been situated in shelf for a while, therefore, the...
3,282
I have an issue with the communication trough the MSG instruction, I want to send information to a printer from a 1769-L35E, I have configured the...
17
16,091
Has anyone else seen or heard of this? I have about 27 connections but seems my message statements are hanging up at times. (usually around 45...
19
7,153
I was told by the user manual and by users that if you have a solid red fault light then the CPU is shot and it needs to be repaired I bought a...
4,900
We have 02nos of 1769-L35E connected through ethernet ports. How to share data between these two controllers?
2,320
