CompactLogix ABL command not working?
cisco_kid
Feb 2007
Portland, OR
I have used this command several times without issue, but never with CompactLogix (L31). The termination character "$r" is specified in the Chan 0 User dialogue, as the 1st term char. I have created a serial port control, ABL_CTRL, to be used only by this ABL command. The ABL is triggered by an XIO ABL_CTRL.EN bit. I have set up a test counter to count the .FD triggers, and it remains at 0.
I expect to use ABL_CTRL.FD to trigger an ARL command.
When I force the ARL command, the data is in the buffer, including the $r char.
I am also doing AWT commands out of this same port. I am wondering if the two (reading and writing) out of the same port are conflicting in some way. I have set up different serial port control tags for each (ABL, ARL, AWT). The AWT portion works fine.
I have considered usisng an ACB command and modifying the .LEN parameter of an ARD control. That doesn't seem as robust though.
Any help is greatly appreciated!
C
172
Hi everyone, i have a compact logic 1769-L18 PLC and I'm using FTalk View ME for the display. I wanted to do some visualization on Grafana. At...
104
Does anyone know what the data transfer rate for this series of CompactLogix PLC's? 1769-L24ER-QB1B to be exact. Cheers.
102
Does this instruction calculate values during a single scan, or does it require number of scans based on element count in the array? For Example...
119
Hello all, and thank you in advance for any assistance you may be able to provide! This is my first post, so if I need to reformat or change...
491
