CompactLogix and FT Alarms
rleon
Aug 2008
Baires
129
Hi:
I was seeing the manual of FT Alarms&Events and indicates that CompactLogix firmware version 16.20 and higher is compatible with FT Alarms.
I have a L32E CPU and upgraded the firmware to version 16.3 But in FTView send me a message "Connection to controller <RSlinx Shortcut Name> has been lost." in my Alarm and Event Summary (but I see the controller in the shorcut and the tags in my displays, in fact, I can start and stop motors from that processor), the message is only from the alarm server.
Anmy idea that I can do?Another firmware?
I am using FTView SE with a client/server connection. The message appears in the Studio and in the client alarm summary.
From the built-in web page of the CompactLogix Ethernet port or using the Logix 5000 Task Monitor, measure how many CIP connections your controller is handling.
This is only a guess, but because FT Alarms & Events uses a separate CIP connection for the alarm subscription, your controller might have too many combined FactoryTalk and I/O connections on the communication port.
So I have Factory Talk ME ver 12 and Studio 5000 ver 32. Hardware is a 2711P_T7C21D8S 7" Panelview Std connected to a CompactLogix L30ER. I am...
2,309
Hi there, I am currently working on a project that involves interfacing PowerFlex525 drives with a CompactLogix PLC over Ethernet/IP One thing I...
3,180
Is there a way to print alarms from either a CompactLogix or a PanelView Plus 1000 via ethernet? I would only need to print certain alarms at...
2,855
Hi All, I'm just trying to understand the reason behind something I recently experienced. Background: The system contains 4 CompactLogix...
141
284
