forqnc
So I have Factory Talk ME ver 12 and Studio 5000 ver 32.
Hardware is a 2711P_T7C21D8S 7" Panelview Std connected to a CompactLogix L30ER.
I am trying to setup my Alarms in Factory Talk and the way I have done this previously, with Micro 1400, was to load a value in the PLC when an Alarm occurred. Then use that value to trigger my message.
So I made a tag and setup as usual, but on loading the HMI I get the message that "Failed to resolve [Tagname] due to not being on any server"
Started researching and found information regarding that you can't use indirect addressing.
Started researching indirect addressing and feel like I keep falling down a rabbit hole.
I tried to make a HMI tag then have it point to the PLC, same error on HMI.
Then I came across parameters, so I tried to set up a parameter list to see if that would work still no good.
I am relatively new to Studio 5000 and the adjustments from RSLogix 500.
If anyone has a simple explanation or can point me to a section in a manual as to how this should work or if it can work I would greatly appreciate it.
I've attached a couple of screen shots showing the errors.
