CompactLogix Controller or Program Tags
irondesk40
Jan 2008
nc
630
If you are creating a program to control a machine and it is a single program would it be best to create all your tags as Controller tags?
If i understand correctly from what my local rep told me that if you want to communicate with tags to a HMI then you should create those as controller tags.
Still trying to get use to the Tag way of programmming after using the Micrologix for the last few years.
Ultimately, it is personal preference.
I much prefer program based tags, as that keeps things together and makes it a simple matter to move programs from one processor to another for re-use.
I use controller tags for things that are truly global.
All HMI's that I have used can deal with reading program tags directly.
Personally, for the type of program you mention, I would use all controller tags. If you had a single controller running 6 identical lines, or 6 different "areas" of a plant then I might separate into different program tags.
With only one program, definitely use contoller tags. I've always used program tags to isolate tags specific to a program that would not be needed elsewhere in the controller. Or it's sometimes beneficial to use the same tagname numerous times but in different programs.
Keep in mind you can still use program tags in an HMI, in particular, AB HMI's.
Good Morning , I'm using a CompactLogix L33ER CPU . A number of my tags are going to be REAL. I looked in the processor manual , and could...
1,434
Hi, I recently installed 2 1783-NATR devices into two of our machines. The machines are pretty much identical, both having 1769- L24ER-QFC1B...
310
Hi, this is my very first thread. I am a PLC enthusiest and am setting up an AB compactlogix 1769-L35E controller with some relays at home to play...
3,102
Hi Everyone, I am a bit new in working with AllenBradley systems. I have a situation where an Compactlogix 5330 L30 controller is installed with...
1,886
Hi We are looking to replace the temp control system on our main oven. we currently run a eurotherm 2416 PID Controller with a single TC but are...
3,145
