CompactLogix DeviceNet AO OE2C config
spaderkung
Aug 2007
South Sweden
389
The point io AO card OE2C will not take any output value. It also resets its configuration (edited in RSNetworkx for DeviceNet) every time power is cycled. As long as the CPU is in run the config is successfully changed on the fly. The card gives 4mA if its low scale limit is set to 0.
On the same bus there are three other point io dnet nodes with DI and DO that are working. On the same node there are working AI and DI (with trouble AO between). The scanner reports no errors. Every node has a 1734-ADN first. I've done the mapping in the PLC myself and most of the mapping in DeviceNet. The AO EDS file is the same as in a functioning application (not by me). The card revision is 3.004.
Any ideas on what I could have overssen are welcome.
We refurbish tube end formers and benders. I'm currently working on an Addison TEF. It has a 1769-L32E with a 1769-SDN DeviceNet scanner (see...
1,654
Hello Mates, first time developing with deviceNet, Im more used with S7 CPUs. My system is a L23E CPU + PanelView 550 on devicenet. I can't...
775
All Found myself in a situation where I need to flash the 1769_sdn Devicenet module from 2.002 to 4.004. I uploaded from the module but it has...
2,408
Hi everyone, Im changing an old 1769L35E PLC and 1769-SDN/B DNET module with a newer 1769L33ER and a new 1769-SDN module. My question is.. I...
1,391
Dear All, I was getting serious issue with Compactlogix L43 Chassis Backplane mounted DeviCeNet 1769 Scanner Card loosing the DeviceNet files...
2,251
