CompactLogix - Import new Tags while on-line?
skyfox
Nov 2006
CA
279
Is there anyway to do this short of creating new tags one at a time while online? PLC cannot be brought off-line nor are downloads allowed. I need to import several hundred tags that are currently not read by any clients but will be in the future. AB allows on-line edits, but I don't see a way to import tags while on-line. Any rhyme or reason for this restriction while keeping in mind that these are brand new tags that are not yet used in logic nor being read by any external clients?
Cheers.
Tags, along with their descriptions, can be created online if you import a program that uses them. When importing programs, I recommend importing them into the unscheduled task area. After examining that every thing looks good, the program can be easily scheduled into a running task. I also recommend trying it offline first so that you get idea of the final result.
Note: local tags are imported with the program without regard to use, controller tags have to be used in the program and are not overwritten if they already exist. Offline you have the choice to overwrite.
245
Hi everyone, i have a compact logic 1769-L18 PLC and I'm using FTalk View ME for the display. I wanted to do some visualization on Grafana. At...
106
Does anyone know what the data transfer rate for this series of CompactLogix PLC's? 1769-L24ER-QB1B to be exact. Cheers.
105
Does this instruction calculate values during a single scan, or does it require number of scans based on element count in the array? For Example...
120
Hello all, and thank you in advance for any assistance you may be able to provide! This is my first post, so if I need to reformat or change...
494
