CompactLogix & Insight Micro 1100
zaniboni-RNBP
Nov 2009
Massachusetts
I am trying to integrate a Cognex Insight Micro 1100 camera with a CompactLogix 1769-L32E PLC. I am trying to use the ethernet communication port build directly into the PLC processor. When configuring the PLC I setup a generic Ethernet module but I am getting a comunication error when I go online.
RSLinx sees the camera and regonizes the IP address - although it does say '? 192.168.0.20, unrecognized device, Insight Micro 1000 Series'. It is not X'ed out like some other things so I think it is seeing it.
Does anyone have any experience with integrating a Micro 1100 with a CompactLogix PLC? I have called Cognex but their support is less than stelar and all I could do was leave a message.
I have not used the Micros but only the 5000 series. The Insight CD comes with an add-on profile. Try that although I do not know if it works with the newer micros.
Just curious if you had any luck interfacing the micro 1100 and the 1769. I am working on a project where I need to be able to change jobs in the camera from a panelview plus. I can get the camera to go offline but can't seem to get the job to change.
Hi everyone, i have a compact logic 1769-L18 PLC and I'm using FTalk View ME for the display. I wanted to do some visualization on Grafana. At...
97
Does anyone know what the data transfer rate for this series of CompactLogix PLC's? 1769-L24ER-QB1B to be exact. Cheers.
98
Does this instruction calculate values during a single scan, or does it require number of scans based on element count in the array? For Example...
116
Hello all, and thank you in advance for any assistance you may be able to provide! This is my first post, so if I need to reformat or change...
486
We are trying to poll data coming from a PLC for remote monitoring we have the IP address of the PLC and the default port number and the path is...
25
587
