CompactLogix L24ER thermocouple issues
Are you using a factory made type J thermocouple with type J wire or just a length of type J wire with the ends twisted together? Do you have access to a process calibrator that can source a TC signal?
If you have a calibrator, you can measure/simulate the signal and see where the issue is (TC or input). As has been suggested, double check your connections for cleanliness. I haven't used the embedded TC input on that PLC, but other modules I've used just worked with minimal fussing as long as the TC and wiring were good.
Hello all, and thank you in advance for any assistance you may be able to provide! This is my first post, so if I need to reformat or change...
481
Whilst commissioning a system using a CompactLogix 1769-L24ER-QBFC1B we have accidentally shorted an output to ground causing the output to stop...
2,649
Hi there, I have 3x SLC 5/04 processors communicating with each other over DH+. Some external equipment is being replaced and a new packaged...
2,252
Hello. I am new to the world of PLC's. We just bought a Compactlogix L24ER QB1B and I am now trying to connect to RSLinx. However, the program...
2,385
Hi all, I have a CompactLogix L24ER QBFC18 with a built in high speed counter card and analogue I/O card. I was using the 2 analogue outputs to...
2,092
