CompactLogix L35e and Micro 820/850
Oliver Micka
Oct 2015
Hlohovec
65
Hi all.
I need litle help.
I need connected Micro 850 ( 2080-LC50-24QWB) to a Main PLC (CompactLogix L35e) and send/recieve data throught Ethernet.
I have a several informtion : How make it.
In my CPU i have MSG instructions for read and write data with Micro850.
I tried change my old processor to a new processor only for test ( same type L35e ), but situation is the same.
But If i change processor to a "newer"L33ERM or L36ERM, everything seems OK. Comm between Micro850 and L33/36ERM was excelent and fast.
I used a same settings MSG instructions.
But L35e - still error " connection failure" in the RsLogix
Does anybody know, why CLX L35e cant send/recieve data throught ethernet with Micro 800 series?
Info:
CPU FW: 20.19
Just a guess but what series is the L35e? if its a series A that may have been the improvements made to a series B but I am not sure
There is a detailed RA Knowledgebase document that you have probably already read that describes configuration of MSG instructions in a Logix-family controller to target a Micro 800 series controller.
https://rockwellautomation.custhelp.com/app/answers/answer_view/a_id/520228
Examine the selection for "connected" message on the Communications Path tab. I believe that it must be "unconnected" for older CompactLogix.
I have tested MSG config for L33/L36, i believe that is the same config for all Logix CPU family. That is why i used the same config for proccessor L35e.
Nothing.
I tried use many address for a Path.
The standard Ethernet address for Logix CPU´s is " 2 " - for example: 2, 192.168.0.1.
If i change address to any number ( from 0 to 7 -I know, it is a nonsens, but i tried everything ) - nothing gonna happen - i have still communication error.
I have a problem and I can't find anything about it in the Rockwell Knowledge Base. The problem is that I am losing communication with a...
1,244
Hi all, I am an amateur PLC user. I am using a Compactlogix L35E. Some time in the past week, the I/O light began blinking green. Whereas...
2,133
Dear All , I need help to resolve the issue of the RPI that has been not changing on my configured L35E processor ? it was running since but now...
1,462
Customer has a radio telemetry master using a Compactlogix L35E Serial port set up as DF1 Half Duplex Master and has been adding remote stations...
2,010
Hi, I am new to PLC and seeking advice here. We have a compactlogix 1769-L35E. The L35E has been situated in shelf for a while, therefore, the...
3,287
