Compactlogix losing IP-address
dmkar
Jul 2007
at home
29
Dear All,
I have a brand new comapactlogix with an internal build-in ethernet connection.
I can give it an IP address. It works fine till i switch off the power. Then the IP-address is gone. And also the communication with the panel.
How can this be fixed?
Thanks.
You need to disable Boot-P after you assign it an IP address.
You will find this on the port configuration tab of the ethernet card properties. Uncheck Enable Bootp
Good Morning , I'm developing a Shift Register Program for a conveyor system. I begin the Shift Register on a conveyor that is roughly 128...
3,634
Hello, I got called in last night on a machine that has a CompactLogix L30ER running that suddenly went into "Recoverable FAult" with the OK...
2,297
I have a machine with a CompactLogix 32e processor and it loses the program if you turn it off for a minute. I thought it was supposed to keep the...
2,179
Hi everybody, I have an issue with the realtime clock on the AB 1769-L16ER-1BB1B. Every time I cycle the power the time reverts to Jan 1, 1998 at...
17
6,033
This has happened several times over the last month. The L18, which is on a UPS, will lose its program and become unresponsive (all LEDs are off...
20
7,599
