Compactlogix PLC Programming Question
eddicuss
Oct 2021
California
Hello. Was just curious, if it is possible to load an image from an SD card on to a Compactlogix PLC that came straight out of the box brand new? or does it require configuring via RSlinx first via USB/serial or ethernet?
See this thread in particular post #23 -- seems like you will need to save the image from a matching controller with 'load on power-up' selected and the save firmware option set.
Make sure to leave the controller on while it is loading the firmware.
ok so assuming I have an SD card with the image acquired from an identical controller, with the "automatic firmware update" and "load on power up" enabled, I could just pop this SD card into the new controller, set it to REM or PROG, then power it up and it will work.
Is there an approximate time I should wait to confirm it is working? Since I know if updating the firmware through Control Flash or RSlinx it takes around 5-10 minutes.
And by flashing it, I just need to insert the SD card with a firmware image (with automatic firmware update enabled) from an identical controller..
Hi (and sorry for my English...:D) is it possible programming a CompactLogix L43 with an ethernet/ip module (1768 eweb) using RsLogix 5000? I...
13,491
Hi everyone, i have a compact logic 1769-L18 PLC and I'm using FTalk View ME for the display. I wanted to do some visualization on Grafana. At...
97
I'm working on troubleshooting a PLC for a piece of manufacturing equipment. The issue I'm trying to resolve is an open wire fault not getting...
532
Hi all, this is my first post and appreciate your advise in advance. I have a job to migrate a system form Mitsubishi FX5U to AB...
844
Hello Everyone, A very important question: We are having trouble receiving analog output cards (5069-OF4) for our CompactLogix PLC racks. I am...
3,200
