CompactlogixL43 IO Blinking issue
Nandraj
Dec 2016
India
51
Dear All ,
I need help about my compactlogix L43 IO LED blinking issue . when power goes off after when we tried it to ON only CPU will powered another DeviceNet and IO Card not showing power and CPU LED STarts Blinking after again we have recycle the power to CPU then after ALL BAckplane IO gets supply . and then controller not go in run goes in fault mode showing the fault Type 01 power up fault and code code 15 IO power detected . when we clear the fault then goes to RUN Mode
what may be the issue .
need help to resolve this
thanks Mr AG ,
When I power ON my CPU I/O LED blinks also I/O power is In steady red . we need to recycle power near to 5 times then after ALL IO will be powered . after that runs good .
One of the analog module 1768-OF4 was inhibit in IO configuration is this will affect the above issue?
Trying to configure the 2nd drive on this machine. It is being difficult. I have the gains speed encoder data all with good data. when I try to...
1,867
Hey Guys, I have a CompactLogix L43 system. The first 1769-PA4 Power Supply has 6 Digital I/O modules, mounted to the CompactLogix and the next 4...
1,555
I have one GE Fanuc IC200PNS002-AC Versamax Network Interface Module and the fault red light is blinking and i have checked in manual it is...
247
I have a Micro820, yes I know they are hated. I have a brand new Micro820 that I programmed with a Micro SD Card. Once I got it programmed, I...
901
Hi, Have very basic knowledge of PLC's. Wondering if someone can point me in the right direction. Our assembly equipment is being run off of...
1,187
