Comparing wonderware <-> siemens
userxyz
May 2002
any
2,768
Hello,
For a customer we need to use Wonderware as Scada software.
We allways have worked with Siemens until now.
What I wanna know is:
1. When we look at WinCC Flexible, is Wonderware Intouch a similar software that is used for HMI's (panels and PC Runtime) ?
2. Wonderware System Platvorm, is this the Scada of Wonderware that is similar as WinCC 7.0 ?
3. Inbatch is something like Simatic Batch ?
4. What's Wonderware Archestra ?
Thanks in forward,
Regards,
Gerry
You should really get in touch with your local Wonderware rep. The Wonderware suite has grown so much and so many ways to implement, they would be your best ally.
I did
I did,
They can tell me more, but can they say it in a Siemens point of view ? I would like to know with what I can compare it regarding Siemens software.
Why did Wonderware grown so much, is it price/quality better then Siemens ?
I did,
I haven't touched Wonderware in ages but when it was first introduced, there was nothing else like it in the market.
Great graphics, graphical representation of a system/process, etc.
After that, everyone else jumped in as it was a lucrative market.
I’m running a micro 820 to measure a tank level, then turning on equipment at certain levels. I have an analog input (4-20) that I’m storing and...
291
How do you go about implementing, on the M580 PLC, how many days, hours, minutes before a predefine event in the future? The RRTC_DT yields the...
1,829
This is a Citect SCADA question I have Six variables of type REAL (Float) to compare and determine (identify) which variable has the highest...
1,427
I have currently made a logic to read Serial input from a barcode scanner. The situation is that I need to read the barcode from the machine and...
2,046
Hello, We are using Schneider SCADAPack 357 and Trimble Acutime 2000GPS. We are getting the data as a string(ASCII) from...
1,485
