comparison between s7-300 and s7-1200
You realise your comparing two different levels of PLC. The S7-1200 is a replacement to the S7-200, its in the small PLC range.
The S7-300 is a medium to large PLC.
The problem im facing is that i have to do the automation in which I/O i have to deal with is near to the maximum limit of the I/O provided in s7-1200. and if i switch to s7-300 it will b under used because of it cost... so i want to compare them properly before making a decision in selecting the series to make a cost efficient yet fully functional project...
And how much DI/DQ/AI/AQ do you need?
approximately 15 AI/ 2AO / 20DO and 12-15DI... but this is a rough figure i may increase to some more I/O .. so if it increases i will have to suffer because the machine have no paper work left and the study have provided us with this amount of I/O but during the process if we over come some problem , we may need some more I/O.. so suggest me a proper PLC ... i m the student of final year of industrial electronics and this is my final year project and i have less knowledge of PLC models as compare to professional... Your help will b grateful
Dear all what is the comparison between PID controller and PLC? when i can use PID controller?, when i can use PLC?, and when i have to use PID...
9,070
Does anybody have a white paper on the comparison/benefits on the difference between PLC's and Soft Controllers.
4,853
i would like to ask for a detailed discussion regarding the comparison between plc and conventional control using relays and contactors in terms...
10,762
Per title - what's the worst and best wire duct brands you have worked with, and why? They all look the same on the outside, but there are...
2,400
I have installed a Cognex barcode scanner on a machine. I have a 1769-L18ER CompactLogix processor. I have communication setup and working. I...
26
4,582
