what is the comparison between PID controller and PLC?
Albeel
Jan 2006
China
Dear all
when i can use PID controller?,
when i can use PLC?,
and
when i have to use PID and PLC togather?
PLEASE REPLY
with my besr regards
PID control for continous process control that solves well with 3 term control.
PLC for discrete control, and state logic.
When you have both, use both.
PID is an algorithm. The most common is a Temperature Controller. A Temperature Controller with a PID feature is commonly called a PID controller. A PID Controller is not limited to temperature. You can use it for any process that needs the same type of control as a heater.
The proper term for a PID Controller is Process Controller.
A PLC is a computer that is designed to control machines. PLC's can have many options. One of the options is PID Control. This means you can have a PLC with a PID Controller built in as one of the features.
can any one tell me the comparison of cpu specification and modules of s7-300 and s7-1200 and also there cost
2,893
Does anybody have a white paper on the comparison/benefits on the difference between PLC's and Soft Controllers.
4,855
i would like to ask for a detailed discussion regarding the comparison between plc and conventional control using relays and contactors in terms...
10,770
Per title - what's the worst and best wire duct brands you have worked with, and why? They all look the same on the outside, but there are...
2,400
I have installed a Cognex barcode scanner on a machine. I have a 1769-L18ER CompactLogix processor. I have communication setup and working. I...
26
4,583
