Compatibility between revisions: ControlLogix processor and DeviceNet card
fwilliams83
Nov 2009
Adelaide
I have a 1756-L55M12 ControlLogix processor which is set to the site standard firmware revision of 16.21 (also the latest revision for this processor). I need 3 DeviceNet scanners in my rack and have been handed 1756-DNB/D cards which have an out of the box firmware revision of 11.03. My problem is that the latest major revision I can set the DNB module to in the Logix5000 hardware configuration is 10; conversely, the earliest revision I can set my DNB card to is 11.02.
Has anyone had a similar issue? Does anyone know of any issues that may arise if I use an earlier major revision number in my Logix5000 hardware configuration to the actual configuration of the card?
There is an article on the Rockwell knowledgebase about this. Their solution is to set the revision number to the highest available and disable the electronic keying for the card. This is obviously a fudge but it seems to work OK.
The I/O and Status connections of the 1756-DNB have never changed, so there is no loss of function to just go ahead and disable Electronic Keying.
I un-key my DeviceNet modules all the time.
Hi, Just looking for a quick pointer. I want to upload an old program out of a Texas 305 PLC. The program was last downloaded in the 90s so...
2,036
Hi guys, I need quick info! I'm working with Simatic manager v5.1 with SP6, what is the latest version and are they both compatible or do i...
1,514
I've come across a system running omeron cx-programmer version 9.42. Am I going to need to find a legacy version of the software to edit and...
68
Hi, Is it possible to for an RIO with Flex 5000 series module, e.g. 5094-AEN2TR, to communicate with an 1756-L72E processor.
103
Hey there friends, recently discovered the world of industrial automation and learned what this fancy PLC can do so i am a super novice. Started...
362
