Concatenate two INTs to one DINT
Nitro
Dec 2011
IN
I am trying to concatenate two INTs into one DINT
I have try following Knowledgebase Article 552006 but I am not having any luck.
I have found this post too which talks about doing the same thing as the knowledge base article
So I am wanting the tag (OfflineWheel.SEQNumber) to read 757494, but I get 32375541.
And I have try the bit field distribute method too.
Any help would be appreciated
Use DTOS on each INT value and Create two Strings to accept values. Then Concatenate into 1 String then use STOD To convert String back to DINT.
To concatenate the values of the two INT tags, do what Ken Moore suggested.
The post that you & Tarik1978 referred to will concatenate the bits of the two INT tags, getting the result that Bernie Carlton mentioned.
Hello All, I have a little problem that I need some help with. I have got a 17 digit number coming from a supplier. It's basically a barcode...
3,067
Hi, I have a list selector which I want to display the recipe found inside a plc-5. The recipe is store in an ascii table with each character...
1,425
Hi all, I have trouble compiling the following simple Cicode function in Citect V7.0r1. Compiling gives the error "Operand expected". FUNCTION...
3,921
I have an existing program for a machine which can run 50+ different parts. Each part has 10 parameters allocated and I have to modify the program...
1,775
Hello Everyone! What I would like to do is generate a random password to be used with the Active X Reset password object. I am currently doing...
1,867
