Conductivity control help
ceilingwalker
Mar 2010
Phoenix, AZ
1,586
Hello, I have a Suntex EC-410 Conductivity controller that feeds a 4-20mA signal back to a compactlogix. I have the manual for this device but no experience setting one of these up. I went to their site for support and it's all in Chinese. I did perform a translate and was able to get some help however, I am hoping someone here has experience setting these types of controllers up. The only real barn burning question I have is, the book says "This controller supplies 4 CELL constant to be adjusted". The four options for this constant 0.01, 0.05, 1.00 and 10.00. The unit of measure I am using is microsiemens. How do I know which constant I am to use? Thank you
I assume your talking about the cell constant for that you really need to documentation on the measuring cell, that should have the constant to apply
Hi All, We are looking for a new paperless recorder, our current ABB SM1000 is on its way out, the screen is difficult to see. There is a long...
2,555
I've been asked to build a "simple" salinity monitor / controller for a chilled brine system. To simplify things, the owner prefers a tank-mounted...
1,952
Hi Guys I need a bit of help here with my math! I have to measure the conductivity of caustic in a line. Now what I have been given by the...
3,580
I'm trying to get the measured conductivity from an Oakton CON2700 conductivity meter into a PLC. The unit has an RS232 output for a printer...
2,350
Hi: Replacing an old open board controller with a small PLC. I have a tank with 5 probes (1 reference and 4 different levels). I need an...
5,795
