config ml 1200 and usb to serial
silentcororo
Jul 2010
Chihuahua
26
:site:hi;
Well from I dont have any serial port on my PC I decided to buy a usb to serial converter, but cant connect my PLC to rslinx.
the way I config my rslinx ver.2.54, first select rs-232 DF1 devices, then see on my device manager the port are installed my usb to serial converter, this case comport 4, then select on rslinx and set next parameters:
com:4
Device
Baud rate: 9600
Protocol: full duplex
the cable number is "1761-cbl-pm02"
thanks all advices
Miguel V.
Did you try "Autoconfigure"?
Is the ML1200 new? Does it have a program in it? If so check the offline file to see how the port(s) are setup or post it here and someone will take a look for you.
See below for the ML1200's default settings.
Set the "Device Type" to "SLC-CH0/Micro/PanelView" and select CRC for the Error Checking type.
The default baud rate for the MicroLogix 1100/1200/1400/1500 controllers is 19200 baud.
The "Autoconfig" feature does not work correctly with many USB/RS232 converters (it does work with the Keyspan HS-19), but the default settings for the MicroLogix 1200 should do the trick.
You can be sure the MicroLogix 1200 is in the default communications mode by pressing the "DCOMM" button hidden near the memory module plug until the "DCOMM" LED is solid green.
You'll need a pin or something to push the button, and it's tricky to get it to register even though you're pushing it.
But as Ken said just push it in different ways for about 5-6 seconds until you see the LED stated light up.
Hi everyone; I have an pv 550 touch, and I want to see him on rslings, I have a usb to serial converter and 1747-uic, my pv has 2 ports DF1...
4,627
I use RSLogix500 downloas backup program to ML1200 via DF1 driver. In the backup program, the channel was configured as "Modbus RTU Slave" So...
1,767
Hi, We have an application that has a device that goes through a reboot (appears un-graceful) What then happens is the MVI module appears to hang...
92
Hi all, I have some difficulties with programming a NAT config in my Scalance SC636-2C When programming the NAT-table i'm not able to reach my...
222
Hello Folks, Has anyone configured a Momentum high speed counter on Unity 13.1. We need the wiring diagram for Momentum High speed counter and...
90
