Configurable Slot Empty Error
imanh
Jul 2009
tehran
21
Hi
I've added a FM 357-2 module to a CPU 315-2 DP. There are three I/O modules before that in the rack.Slot number is 7.
I add it's component in STEP7 hardware cinfiguration but the SF light become red in both CPU and FM. the DIAG and STOP lights also turn on.
In Diag. Buffer of CPU there are several "Configurable Slot Empty Error":
Event 10 of 100: Event ID 16# 5961
Parameter assignment error in CPU module parameters
Parameter: module type
Input address: 304 of the module with parameter assignment errors
Error type: configurable slot empty
Operating mode: STARTUP (warm restart)
External error, Incoming event
12:26:40:384 pm 09/05/09
What should I do?
Does anyone know of a counter block (either PLC or PAC) that allows configuration of the input signal, such that it can be set to count up/down on...
729
Good Evening , I have some Rockwell Light Curtains and Guardmaster 440C-CR30 Configurable Safety Relays . I was wondering if there is any...
1,407
Looking for suggestions for a large screen display (greater than 37in) with wifi that will boot directly to a web browser, then point to the same...
25
7,966
Hello everyone. I am currently doing a project to teach about ethernet topologies such as ring or bus. For example. But instead of using an...
4,365
Good Afternoon , I'm having my first experience with a Guardmaster Configurable Safety Relay 440C-CR30. So far , I really like the...
1,631
