Configuring a siemens 6es7138-4cb11-0ab0 module
rootboy
Jan 2004
Tennessee
1,375
Hi Guys,
We had a siemens 6es7138-4cb11-0ab0 "Power Monitor" module either fail, and/or lose its configuration today. According to the manual, it comes setup out of the box as a 24 volt device, and if you want to use it to monitor 110AC, you have to configure it to do so.
Other than Step7 how do you configure one?
Thanks!
I am working with an Emerson CPL410 PLC that is connected to a Siemens AI 8xU/I/RTD/TC ST (6ES7531-7K00-0AB0) via Profinet (and a Siemens Scanner...
1,553
Hi all, Now I am working with Sicam P50 multi function meters. It have 2 sets of Analogue outputs. I want to know how we can check its working or...
1,519
For one of the projects, Customer has Profibus Network as below, Profibus Master 1 - PRM Module (Schneider) addressed (1) Profibs Master 2 -...
3,344
Hi there. I'm new to the Siemens world. I'm trying to set up the PLC using the STEP 7 Software. Ultimately, after I've created a configuration...
12,582
Hi guys, I'm totally new in Siemens, currently I'm working on a proposal to add in 2 more slave node into the existing profibus network...
4,060
