Confused "again" S7 indirect
That is correct it only works when restarting
So FR i think will mean Flank Reset?
So what you are saying instead of reseting the timer i can do the FR of the timer and that would do the job to work with jumps ?
I think
It is quite strang "stupid" that you can reset a timer in 2 different ways once with "FR T1" according to the manual Enable Timer and once with "R T1", according to me it is doing the same except FR does a better job :)
Then i would propose to never reset a timer any more just FR it, or do i see this wrong
After testing i noticed that i will stay working without the jumps.
i cant get it working with the jumps not even with the FR in the manual if you read the phase diagram it never points out when you should put the FR high to enable the timer but ok i tried it before the timer and after the timer it only works when i restart the plc
It is probably getting late will have a better look at i tomorrow
Thx
Miika said:
In your code timeformat is not suitable for timer. You should give it in BCD-format.
Add ITB command before timer.
Sorry can you be more specific don't know what you are talking about. The timer format according to me is S5T#....S
Thx
Which of the following input operations require a conversion to digital form prior to input? a) disk b) analog c) contact closures d) limit...
3,883
Hey all! I recently purchased myself a Panelview Plus off of ebay and i was hoping that i could upgrade the firmware on it to Version 9 or so and...
2,746
Good morning everyone. I am apparently confused on the COP instruction. What I am trying to do is copy a DINT to a DINT in a User Defined Data...
6,961
Hey guys, Im currently using the above flex IO to turn on two outputs these outputs go to two flashing red beacon lights. Here's the scenario: My...
1,710
I'm event AV Technician (Sound, Projection, and Lighting). Over the last couple of years I've used a Weigl ProCommander PHX to control some event...
2,699
