Confused by Active and Passive-Master/Slave!
Apel
Aug 2007
Singapore
98
HI,
Can tell me the defination of these terms -Master/SLave and Active/Passive in automation field?
I found: in computer networking, master/slave is a model for a communication protocol in which one device or process (known as the master) controls one or more other devices or processes (known as slaves). Once the master/slave relationship is established, the direction of control is always from the master to the slave(s). The County of Los Angeles, saying the term master/slave may be offensive to some of its residents, has asked equipment manufacturers not to use the term. Some manufacturers prefer the term primary/secondary.
Other communication protocol models include the client/server model, in which a server program responds to requests from a client program, and the peer-to-peer model, in which either of the two devices involved can initiate a communication session.
cheer
Master Slave network will have one and only one master, who can initiate a messgae to read/write to any slave device on the network. All slave device will just respond to a request from the Master. A slave device cannot directly communicate to another slave device. A slightly advanced version of this is called MSTP ( Master Slave Token Passing ). In an MSTP network, a token is passed among the devices in the network and when one device gets the token, it can act as a master and request read/write to any other device. The token is passed from once device to another based on the ascending node number and each device get chance to be a master for some time.
Active network generally needs a power supply on the wire where passive network dont require power ( eg. thermocouple, RTD etc. )
Hello apel;
In your post I find no mention of passive/active definitions in communication networks. Could you please give an example where the opposition master/slave and passive/active is determined? maybe we could understand the question better.
Regards,
Daniel Chartier
Concerning the controversy over terminology - not to be a knee-jerk politically correct person - but I believe that 'master/slave' does not quickly and accurately convey the communication relationship. I like 'initiator/responder' myself.
Dear Daniel Chartier,
I am doing one simple communication job right now and confused by two manuals.One device is Schenk Weigher MULTICONT which is serial RK512/3964R protocol device and is 'Slave Device'.This device is to be connected with one Serial to Profibus-Dp gate(this gate is called Passive device)...now the probelem is that who will initiate communication between serial and Probibus Dp....gateway is connected with ProfibusDp master.
confused! again
Which of the following input operations require a conversion to digital form prior to input? a) disk b) analog c) contact closures d) limit...
3,894
Hey all! I recently purchased myself a Panelview Plus off of ebay and i was hoping that i could upgrade the firmware on it to Version 9 or so and...
2,759
Good morning everyone. I am apparently confused on the COP instruction. What I am trying to do is copy a DINT to a DINT in a User Defined Data...
6,996
Hey guys, Im currently using the above flex IO to turn on two outputs these outputs go to two flashing red beacon lights. Here's the scenario: My...
1,720
I'm event AV Technician (Sound, Projection, and Lighting). Over the last couple of years I've used a Weigl ProCommander PHX to control some event...
2,718
