Connecta S7 300 with VB without OPC Server
contope
Jun 2007
BA
DEar All,
I´m trying to develope a little application (like a little Scada) inwich I have to communicate my PC with a PLC Siemens S7 300 via Visual Basic.
I understand I could use an OPC server but is out of muy budget. I read something from "DesertDog" saying it is possible to do it witho out any extra sofware.
COuld any body tell me somthing more about it?
thank you very much
The only free driver for S7 communications is libnodave. All the orther drivers are not free. (Simatic Prodave, Deltalogic, MHJ, etc)
Assuming your S7-300 has an ethernet card, you wouldn't need a canned "driver". A cursory knowledge of sockets would be enough to communicate with VB directly.
34
Hi Siemens guys! I am experiencing SF fault on our S7-300 (6ES7 315-2AH14-0AB0) CPU from time to time. I've checked the diagnostic buffer and...
174
Have a system that has been running for over a year and all of a sudden getting a ExcessiveVelocityFault on one of the drives when the MSO command...
144
Hello PLCS.Net Forum, First time posting. Let's assume I am a novice. BASIC PROBLEM: My servo/linear piston is no longer zeroed to the...
218
hi... i have an issue in s7 300 plc, while we run the machine(in idle there is no fault) , plc cpu goes in SF mode, after restart the power cycle...
117
