I downloaded and installed the Connection Components Workbench Standard and have followed your video to the point where I setup the connection path, I click Browse and the next window shows Linx Gateways, Ethernet and AB_ETHIP-1. Ethernet. I attempt to expand the AB_ETHIP, Ethernet and the plus sign changes to the minus sign but nothing pops up under it. My network is configured to an IP address of 192.168.1.73 in the Micro 800 simulator and set my network setting to 192.168.1.123. I went to configure drivers and set The IP address of the AB_ETH-1 and AB_ETHIP-1 to 192.168.1.73. When I attempt to ping the IP address, I receive "Destination host unreachable". Finally, Micro 800 Simulator is showing a fault of 0xF019m "An unexpected software error occured due to memory or other controller resource issue."
I'm taking an assessment January 6 for a new job and about half the test is on programming with RSLogix 500 on Allen Bradley PLC's. I desperately need to pass this test. Any help will be greatly appreciated.
