Connecting other plc with wincc
Hello navid007.
WinCC can be an OPC client.
So all you need is an appropriate OPC Server for the hardware that you intend to use with the Toshiba PLC.
As I do not know the Toshiba PLC, I cannot say if you can connect it with a Master-to-master profibus connection. This would be quite easy if it is possible.
If not, there is the possibility to let either WinCC or the Toshiba PLC be Profibus slaves.
If you can consider other networking standards besides PRofibus, then you shall just have to find one that provides an OPC Server for which WinCC can connect to as OPC Client.
It's like JesperMp said.
Take a look at www.kepware.com
They have drives for the Toshiba T2, but only for Ethernet and Serial, not for Profibus. So what you have to do is to keep the existing connection between WinCC and the other PLC's in Profibus, and create another connection in ethernet between WinCC and the Toshiba PLC and use for example the OPC Server from kepware (KepserverEX)
I received the following PM this morning from new member navid007, writing from Tehran: Connecting wincc to other PLC such as Toshiba Hi...
3,066
I have 2 PLCs. One is networked to our plant, and the other is networked to the first PLC via a 1756-EN2T. I could easily get the second PLC...
69
Good Day to all of you, this is my first post, i will try to explain as best as possible, english is not my natural language. I am performing an...
85
I haven't encountered problems connecting to a PLC through VM Ware but I am with this particular machine. I'm running Windows 7 on a Windows 10...
258
please using the usb can i assign any ip address that i want ?
164
