ragav_rp Member R Join Date Apr 2005 Posts 4 Apr 26, 2005 #1 I want to know the hardware needed to connect SIEMENS S7-300 CPU-315-2DP through MPI port of PLC to the COM port of PC? Thank you.
Doug_Adam Member D Join Date Sep 2002 Location Perth Posts 948 Apr 26, 2005 #2 Had one a month ago, but gave it away. The MPI to USB converter is: 6ES7972-0CB20-0XA0 USB to MPI Although this is not what you asked for. Doug
JesperMP Lifetime Supporting Member + Moderator Join Date Feb 2003 Location ᚴᚬᛒᛅᚾᚼᚬᚠᚾ Posts 16,342 Apr 26, 2005 #3 The PC adapter that will connect to your serial port is: 6ES7972-0CA23-0XA0. You will need a null-modem cable (6ES7901-1BF00-0XA0).However, the PC adapter for the USB port that Doug mentions is much better and cost the same.
