Connecting PC to PLC through MPI
ragav_rp
Apr 2005
I want to know the hardware needed to connect SIEMENS S7-300 CPU-315-2DP through MPI port of PLC to the COM port of PC? Thank you.
Had one a month ago, but gave it away.
The MPI to USB converter is:
6ES7972-0CB20-0XA0 USB to MPI
Although this is not what you asked for.
Doug
The PC adapter that will connect to your serial port is: 6ES7972-0CA23-0XA0. You will need a null-modem cable (6ES7901-1BF00-0XA0).​
However, the PC adapter for the USB port that Doug mentions is much better and cost the same.​
I have 2 PLCs. One is networked to our plant, and the other is networked to the first PLC via a 1756-EN2T. I could easily get the second PLC...
66
I haven't encountered problems connecting to a PLC through VM Ware but I am with this particular machine. I'm running Windows 7 on a Windows 10...
256
Hi, I want to exchange data between two L55 PLCs using ENBT PLC1 is the main PLC and consist of 1756- CNB, L55 CPU and ENBT. Five remote I/O racks...
1,040
Hello, In my project work i am Connecting two Allen-Bradley HMIs (PanelView Component C600 and PanelView Component C1000) to Allen-Bradley PLC...
3,147
Hi, I've never written a program to gather data from a PLC before so I'm very new to this. I've found a lot of information about the DF1 protocol...
7,955
