connecting PLC using RJ45
Apr 2011
Manila, Philippines
295
Hi there guys!
I set-up a connection of our PLC (GE fanuc 9030) to our computer using RJ 45, I configured the properties in the Ethernet Tab of CPU374, IP address, subnet,gateway.
after that, I downloaded the program to PLC using RS232 first. I expected that after I downloaded it I can connect to PLC using the RJ 45 connector (because the PLC now is on the network). I checked the communication by pinging it using command prompt but it was not detected. any suggestion or correction with my diagram?
Thanks for the help guys.
Still it doesn't connect to PLC. Hmmm Im thinking to set up a small network wherein I can access the PLC through network.
I also want to know why is it that the CPU has 2 ethernet ports? is it for data IN and the other is for data OUT? hehehe thanks guys!
If you haven't already, try removing your "gateway" setting. From your diagram you have this set to the IP address of your router - this is not necessary unless you are trying to bridge systems with two different protocols.
Steve
Hi All, I have a closed loop stepper motor (Nanotec make), https://en.nanotec.com/products/2512-pd4-e601l42-e-65-4. This uses MODBUS TCP for...
3,927
Hey guys, just wondering if any of you smart people know a way to connect to a PLC remotely. What we've done traditionally is send a VPN router on...
3,696
Hi all, I tried to connect to a FX-48MR PLC for more than an hour last night with no success. Can someone tell me where the "FX" option is in...
2,634
Hey everyone, I am brand new to this forum as well as OMRON. I am trying to connect to my CP1E-NA20DT-D using the RS-232 port on my PLC to my...
2,165
Dear All, I would like your help on my problems for connecting PLC Omron CJ2M-CPU32 Series using Vijeo Citect SCADA. As i have read in some...
5,051
