Connecting Omron PLC using Citect SCADA v6.0
budiman
May 2013
Medan
43
Dear All,
I would like your help on my problems for connecting PLC Omron CJ2M-CPU32 Series using Vijeo Citect SCADA.
As i have read in some forums, that to connect is using OMFINS driver, that in Omron would known as Omron FINS Ethernet driver.
But i have tried to configure the CITECT by myslef but it keeps on failed.
Would you mind to help me solve this problem?
The problem is only for communicating problem and i do not know what is the configuration for OMRON PLC CJ2M-CPU32.
Here i attached the pics that i capture from CITECT v6.0
Thx.
Best Regards,
Budiman Chandra
V6.0 is very old - better to update for a start. I have never used the OMFINS driver as it is quite restrictive with the newer PLCs as to the word types that can be accessed - it is also very old. I normally use the Omrons FINS software and then configure the newer Citect FINS driver to work with the Omron software - access to a greater number of word types. Another option would be OPC but I have never used it - tried it once and not a huge fan.
Dear BobB
i have same problem with cj1m plc. i wana to connect citect V7.1 to my plc via serial port.
what are configurations for this communication ? o_O
tanx
Hey everyone, I am brand new to this forum as well as OMRON. I am trying to connect to my CP1E-NA20DT-D using the RS-232 port on my PLC to my...
2,157
I would like to connect a touch panel from Siemens (TP27 10 inch) to a Omron CQM1 PLC. I have tried to make a cable for it but it is not...
4,834
Omron Hmi Nt30-ST131-E Showing Connecting host Screen Shot: http://prntscr.com/jca6eh Cpu to Hmi Communication Via Rs232c Connection ok. I dont...
3,353
Hello, I was unable to connect to and OMRON HMI :ns5-sq11b-v2 using CX Designer version 3.6. I connected directly into the Ethernet port at the...
4,399
I am trying to connect my 7" Omron NB7W-TW00B HMI to my AB CompactLogix L-31 PLC. Right now I am just trying to pass a single value from my PLC...
3,924
