Connecting OMRON PLC to CX-Porgrammer using RS-232 to RS-232
mstewart1516
Oct 2016
Ontario
Hey everyone,
I am brand new to this forum as well as OMRON. I am trying to connect to my CP1E-NA20DT-D using the RS-232 port on my PLC to my RS-232 port on my laptop.
When I try to connect it is telling me "Failed to connect to the PLC". Is it possible to go RS-232 to RS-232? I am trying to use COM5 (Communication Port) but I have also tried COM3 with no success.
I have tried using CX-Network Configuration Tool to find my PLC but still again with no luck.
Any help would be greatly appreciated!!
Thanks McKenzie
I have found a USB-A to USB-B cable so I am now playing around with that but I am still getting a failed to connect to plc message. I have checked my device manager and under other devices tab it does say OMRON-PLC.
Any suggestions?
Thanks McKenzie
With CX-Programmer open, double click on the plc in the project workspace on the left of your screen. This should open the Change PLC dialog box.
There should be a Network Type pull down towards the bottom of that dialog.
What is the Network Type listed?
Depending on the Network Type, you should also click on the Settings button to verify details of the configuration.
Hope this helps.
Dear All, I would like your help on my problems for connecting PLC Omron CJ2M-CPU32 Series using Vijeo Citect SCADA. As i have read in some...
5,040
I would like to connect a touch panel from Siemens (TP27 10 inch) to a Omron CQM1 PLC. I have tried to make a cable for it but it is not...
4,834
Omron Hmi Nt30-ST131-E Showing Connecting host Screen Shot: http://prntscr.com/jca6eh Cpu to Hmi Communication Via Rs232c Connection ok. I dont...
3,350
Hello, I was unable to connect to and OMRON HMI :ns5-sq11b-v2 using CX Designer version 3.6. I connected directly into the Ethernet port at the...
4,397
I am trying to connect my 7" Omron NB7W-TW00B HMI to my AB CompactLogix L-31 PLC. Right now I am just trying to pass a single value from my PLC...
3,922
