Connecting Siemens 151-8 PN/DP CPU first time
spandy16
Dec 2012
Germany
58
I tried to connect the SIEMENS IM 151-8 PN/DP CPU first time over PROFINET with my PC. I started the Siemens Port Configurator and included the PROFINET mode as well as the IO-Link master. But I don't know how to configure the IP address. It's not clearly mentioned in the Siemens manual. It's showing me connection error. Only thing I know is that MAC address is mentioned on the CPU box. Please help me with this.
From the hardware config. Hit the download
Button. I also assume your pg pc interface
Is set to Ethernet
Show a screen shot
Is set to Ethernet
Show a screen shot
Sorry, I forgot to mention that I am using the latest S7 professional suite V11 i.e. the TIA portal.
Screen shot
Thank you for the detailed reply. But when I am trying to Go online then it cannot establish the connection. But when I go in the 'accesable devices' option it's detecting some IP and I am able to flash the 'FRCE' LED on the PLC.
Hi All, I have a closed loop stepper motor (Nanotec make), https://en.nanotec.com/products/2512-pd4-e601l42-e-65-4. This uses MODBUS TCP for...
3,915
Hello, I'm attempting to connect to a Siemens S7-1200 CPU with an unknown IP address. I'm new to Siemens and also new to using VMware. I've...
1,959
Hi ! i need to connect 2 plcs . S5 Siemens to > Unisream of unitronics . my idea is to do RS232 by the I/O . Meaning to use 1 output from the...
2,171
Hi everyone Does anybody know if it's possible to connect a termopar to an analog input directly? being more specific Siemens S7-200 analog input...
1,692
Hey all, Trying to go online with an outdated Siemens s7-200. I have the correct cable I believe (PPI Multi-Master Cable - PPI-RS485 on one end...
1,652
