Connecting Siemens MP panels together
orense
Apr 2006
Norway
196
Hello,
I have a MP277 panel in a control cabinet. A 315-2 DP is connected to the panel through Profibus DP.
The client wants another MP277 panel in another room, 25 meters from the control room. They want the exact same screens on that panel, i.e. they want to have a slave panel which is basically the same panel, showing the same screens.
Does anybody have any suggestions for the easiest solution?
I know about the smartaccess licence, but I have never used it. Anybody used it before?
Thanks for any answers...
brg
Andreas
I loved Bergen when I was there!!
I have setup comms between multiple HMIs but my project used a PC Runtime and a MP377. Didn't mess with Sm@rtAccess but used a small script to 'hand over' control between the panels.
Also configured the screens with 'enable object' to disable buttons when the station wasn't in control.
I can post some code if you like
Hope this helps
Hello Elake,
Hehe, Bergen is ok when it's summer. The rest of the year it's snowing and raining... I'm glad you liked it :)
Would be nice if you posted some code. It's the only thing I need, really, possibility to change between the panels.
I appreciate it, thanks !
brg
Andreas
Just make a duplicate of the first HMI with a different address.
This would be the simplest solution if your panel doesn't have any recipes. If you have recipes on the panel then they wouldn't be updated on the other panel after making changes. If you have recipes or other higher level functions then you might be better off with the smart access route.
Nick
Hi All, I have a closed loop stepper motor (Nanotec make), https://en.nanotec.com/products/2512-pd4-e601l42-e-65-4. This uses MODBUS TCP for...
3,942
Hello, I'm attempting to connect to a Siemens S7-1200 CPU with an unknown IP address. I'm new to Siemens and also new to using VMware. I've...
1,966
Hi ! i need to connect 2 plcs . S5 Siemens to > Unisream of unitronics . my idea is to do RS232 by the I/O . Meaning to use 1 output from the...
2,174
Hi everyone Does anybody know if it's possible to connect a termopar to an analog input directly? being more specific Siemens S7-200 analog input...
1,695
Hey all, Trying to go online with an outdated Siemens s7-200. I have the correct cable I believe (PPI Multi-Master Cable - PPI-RS485 on one end...
1,653
