Connecting simatic S7-200 with pc problem
prosteneni
Mar 2011
praha
Hello, I hope that some of you will help with this.
I have PLC Simatic S7-200 CPU 224XP and I have a PPI cable(it has no conversion unit on it) and I cannot connect to the PLC, I am using step7 win software a everytime I try to cennect the program says that it could not connect that I should check some thing". Could anyne tell me please how to properly connect PC with PLC.thanks
on the package is written "PC to RS485 adapter for SIEMENS S7-200 PLC" and at both ends of the cable is the same plug.
The PC side is RS232 and should be a 9-pole female D-connector, The PLC side is RS485 and should be a 9-pole male D-connector. Do you have any more information about this cable, because it surely is not a Siemens original. Those all have indications for PC and PLC side.
Regards,
It is not original Siemens cable, but it has 9 pins on both sides and fits into PC and PLC as well. I bought it in a shop where they told me that it could be used for communicating with plc. It has no conversion unit, that is true. So do you think that if I bought aditional conversion unit between RS232 and RS485, that it might work, or can there be other problem? Thanks for answers
If anyone knows how to connect Wonderware to a Siemens S7-400 please let me know.
2,044
Hi Guys I have a couple of issues with a simatic panel The first issue is that I cant connect to it. I have bought a new panel it is a simatic...
2,012
How could I connect CPU Siemens 319-3 PN/DP to a SQL database server? How could I make this PLC writes and reads data to and from SQL server...
17
28,529
I have a TI System 505 with a SIMATIC TI525 PLC. I'm trying to talk to it using a DDE Server in Windows 3.1, and it has limited options as to...
1,381
Hi Everybody, My problem is that on a UV desinfection channel, there is an intensity sensor giving 4-20 mA signal to plc siemens simatic S200.A...
7,229
