Connecting to Siemens 319 PLC
jackhenkel
May 2012
Grand Rapids
62
Ok, I want to download my S7 program into my CPU 319-3PN/DP. The problem is I can't even get my PC to talk to the PLC. My ethernet cable is connected and the lights are blinking so it appears the cable is fine. I am wondering if I have the wrong IP address? How do I find the IP for my CPU? I am sure one has already been set.
Have you used this PC before to successfully communicate via PROFInet or is this the first attempt at it (PC <--> PLC)?
If your laptop is running Symantec Endpoint, you might need to disable it. We experienced a similar problem here with our laptops running Endpoint Protection and PROFInet.
Correct settings in Pg/PC interface?
I have used this laptop to connect to this exact PLC before. I have made a little progress as far as atleast seeing the PLC. Now when I go to download I am getting "Online: SN_SERV not started"
I think this whole issue was caused by my laptop. I used a co-workers laptop and seemed to be easy. I reconnected my laptop and everything is working fine. Not sure what happened but I think I am good to go. As JRW said the edit ethernet nodes is what I needed. Thanks for the help.
Hi All, I have a closed loop stepper motor (Nanotec make), https://en.nanotec.com/products/2512-pd4-e601l42-e-65-4. This uses MODBUS TCP for...
3,874
Hello, I'm attempting to connect to a Siemens S7-1200 CPU with an unknown IP address. I'm new to Siemens and also new to using VMware. I've...
1,945
Hi ! i need to connect 2 plcs . S5 Siemens to > Unisream of unitronics . my idea is to do RS232 by the I/O . Meaning to use 1 output from the...
2,163
Hi everyone Does anybody know if it's possible to connect a termopar to an analog input directly? being more specific Siemens S7-200 analog input...
1,685
Hey all, Trying to go online with an outdated Siemens s7-200. I have the correct cable I believe (PPI Multi-Master Cable - PPI-RS485 on one end...
1,648
